Hay, lately I have been having several problems with AutoCAD 2014.
1) When I make a line-I used to be able to type in the start point, angle, length, and end point. Now I make a line I don’t have that option. Furthermore I hover the muse over line and try to make an extension of for example 3.5" from the start point after I hit enter it will put the start point at what i think is a random point of the screen. How can get the options back.
2) When i presspull an object-When i would presspull an object i would (with my mouse) drag it in the direction that wanted it to go hen type in the lengh. So if i were to pull it to the right then type in the number it would go to the right. now it goes let no matter what. How can change that
Solved by Jay_B. Go to Solution.
