AutoCAD Forum
Problems opening drawings drawings with Xrefs
6 REPLIES 6
Vitornis
351 Views, 6 Replies
I'm having problems with my Autocad opening drawings with xref's. This only happens on my computer. Other computer at the office will open the drawing just fine. If i open the drawing with one of the other computers i can de-attached the xref files and i can open the drawing normally on my computer. Also i can attached the xrefs back into the drawing after it is open and i can work normally. But if i close the drawing and try to reopen it with the xref's attached it'll crash every time. Anyone have any clue's why this would be happening?
6 REPLIES 6
rkmcswain
in reply to: Vitornis
What is different about your machine and the other ones?
What version and SP of CAD?
What O/S on the machines?
Have you tried RECOVERALL on these parent drawings on a machine where it does open okay?
R.K. McSwain     | CADpanacea | on twitter
Vitornis
Some of the machines are identical to mine.
2013 lastest service pack.
windows 7 and vista
yes
Vitornis
Oh and another oddities i noticed was that i can publish the drawings just find but if i try to open it to edit it will crash.
jggerth
one thing you might want to try is to boot into whatever diagnostics mode is on that PC< and run the RAM tests.  Occasionally a bad stick of RAM can result in weirdly unique problems.
I would check xloadctl on your machine and the ones without the issue. if you have alot of xrefs it can hose a file open operation while it reads all those drawings into your designated temp folder.
Vitornis
I think i have finally figured out the solution to this. It seems to only be an issue where I have a drawing that has a Civil 3d drawing attached to it. I think on some of the computer the Object enabler for Civil 3d is causing the crash.
”Boost
