When I try to load a saved view (3D)(AutoCad 2014) whether in Paperspace or Modelspace, the view in question shows briefly, then quickly reverts back to plan view. I cannot figure out why. Is there a new variable setting that I am not aware of? Note also, that when I save a drawing, AutoCad often save the drawing by jumps to the next open drawing.
Can you reproduce that with a new drawing? If so then please upload that new drawing and let use know the exact steps for recreate that issue.
If that can't be reproduced then please try to copy the content of your current drawing into a new drawing (using copy & paste or _COPYCLIP and _PASTECLIP) and see if that happens there again.
I had that some time ago and really not often. Are you sure you are up-to-date with your service packs? (>>>click<<<)
- alfred -
