I downloaded a designer furniture file (which is a 3Ds dwg file). And I've been just playing around with AutoCad, so I can convert the DWG to a 3D file to test the 3D printer. I'm trying to make scaled down furniture for a modeling project. But I can't seem to convert the dwg into stl (which the 3D printer needs). At first I thought it was the file itself. So, I just quickly opened up a new file, created a 3d cylinder, and see if it would export as stl, it did not save to anywhere on my computer.
Is there something I'm missing? Or anything that I'm doing wrong?
I'm using AutoCAD 2014 for Mac.
I've attached the original dwg file
exporting to STL asks you the following for selecting the objects:
Select solids or watertight meshes:
And that's not the case with your geometry, that are single (not watertight) 3d-faces. You have to work over it.
- alfred -
