I have a problem with a dynamic block that i tried to describe in the following video:
https://www.screenr.com/UzrN
Find attached the file with the dynamic block.
Thanks in advance!
Solved by Yorx57. Go to Solution.
Hi FilRib,
I'm not sure exactly what is going on with your block other than it might have something to do with using 2 linear parameters. If you drag the left over to the right far enough, you will see that it will disappear at the same spot the right one does (pullling the right one to the left). I have simplified it down using only 1 linear parameter and everything seems to be working correctly now.
I was able to look at your block some more and discovered that if you erase the left linear parameter (Distance 2) then the right stretch does behave correctly. So it appears that there is a conflict between the 2 linear parameters.
