Drawing attached normally opens in AutoCAD 2014, but when you want to open in AutoCAD 2015, the program stops working. In the drawing, there are several common AutoCAD blocks.
Any sugestion?
Win 7 64bit
HP EB 8770W, 2.8 i5, 8 GB RAM, 250 GB SSD
Can confirm:
Opens fine in 2013 and 2014
Will not open, or open using "recover" in 2015.
Can not insert as a block using 2015.
Using a Map Query to import portions of it does not work in 2015 either.
An audit in 2014 shows no errors.
Presuming you are on subscription, submit a support request and include this drawing.
