I drew two rectangles of different sizes, having a common corner and two sides. Now it tries to move one of them, but move two at a time, as if they are glued together. I would ask for advice on how to make a shift of one rectangle, so that the latter remained unchanged. Autocad 2014 Mac OS X.
Go to the parametric menu and select constraint settings. Infer geometric constraints is porbably selected. Deselect it. Once done you might still need to delete any constraints automatically set on the other geometry.
