Welcome to the Autodesk Forums!
Does this happens every time or just once?
You can check polylne width at each vertex (both start and end) with Properties palette - select polyline, than "walk" through vertexes in Geometry section with Vertex field.
What do you see?
Maxim
Hi Maxim:
Thank you for your reply. Acturally, when I open the Orthographic Mode, it didn't happen. In addition, when I draw the arrow head individually without the tail, it was also normal.
I am really sorry to say I cannot totally understand your answer. I learnt the software several years ago and almost forget everything till now. At present, I am forced to pick it up because of my job.
Brian
Hello
Welcome to the Autodesk/AutoCAD forums !
Maybe a stupid idea !
Could you select the objects in Capture Mode ?
Have you ONLY Pline Entities or have you some very old Trace Entities ?
Bye, Pat
Patrice BRAUD
Hi Brian,
That is what I'm talking about:
Here is Command prompt output during creation of polyline you see on screenshot:
Command: PLINE
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]: w
Specify starting width <0.0000>: 10
Specify ending width <10.0000>:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: w
Specify starting width <10.0000>: 40
Specify ending width <40.0000>: 0
Command:
Have you tried to turn off object snap during polyline creation?
Maxim
It is not always. I tried this afternoon again, it happened occasionally. The attachments include the command prompting and the process to the end. In addition, you will see some Chinese words as I use traditional Chinese as the language. If you don't know that, just focus on the command and foget about the Chinese things.
Thank you very much Maxim
Best Regards,
Brian
Graduate Engineer
FYFE
Hi Brian,
I was able to reproduse your issue with polyline.
It looks like a bug (or feature?) of polylines with variable width.
If you will try to stretch with grips the end of polyline with constant width - you will see such effect.
Maxim
Hi Maxim:
Thank you. It is now very clear for me with your help. Today I am studying layout printing. How to put the pictures in the model into the layout with certain scale and place. In addition, I have no ideal about the command "MView".
By the way, do you use some chat tools, like whatsapp, skype, msn or anything else? I sincerely want to be more closer to you.
Best Regards,
Brian LUO
