AutoCAD Forum
Problem to draw a line ._.
3 REPLIES 3
Neikohl
368 Views, 3 Replies
yeah I know that it sound stupid, but I really have a problem to do it. I am designing a logo for a group and I had a problem to fill objects, after some time I found out how cause I tryed everything and now it's not possible to draw a line. Instand of a line a square appears. I uploadet a screenshot and the file of the projekt. I think the problem is that I activated something wrong.
I am thankfull for all help I get 😄
- Neikohl
3 REPLIES 3
Patchy
in reply to: Neikohl
Type in THICKNESS use zero
Kent1Cooper
You have the THICKNESS System Variable [which is vertical, up into the Z direction, not to be confused with Lineweight, nor with Polyline Width] set to 5.2607.  Set that to 0, and see whether that fixes it.  If that's the only issue, you should not see the problem when you draw something in Plan view, but your sample drawing as posted is looking in a different direction.
And, by the way, welcome to these Forums!
Kent Cooper, AIA
Neikohl
Thx for the answers, everythink is working fine now and I can finish my work ^_^
”Boost
