I have a problem with X-REF. my X-REF is not loading automatically. Also It can’t reload. Every time I have to attach the same files. (Its locations and file name never changed) anybody can help
Hello
Very strange !
So with ACAD 2014 (Have you installed the SP 1 ?) you said that you can select the DWG XREF but you can't ReLoad it !
Of course you can browse the HD and/or Network and attach the DWG and the Path is the SAME !
Please could you run this VLisp routine from Gilles (gile) - You load it with APPLOAD command
- X0 will unload ALL DWG XREFs
- X1 will reload ALL DWG XREFs
- Commands I0 & I1 do the same job with Images ...
Please could you confirm that the X1 command will not reload the DWG XREFs !?
We assume that the files exist and the Path are correct !
Patrice BRAUD
Hello
Some other ideas :
- Have you special characters into the filename or into the path ?
- Is the Path too long : more than 255 chars ?
Same probleme with the X1 command coming from the VLisp routine ?
Patrice BRAUD
