AutoCAD Forum
Problem drag and drop to insert image
4 REPLIES 4
Peac3
6891 Views, 4 Replies
I have this situation in 2013, i use to take an image from my left screen file manager in good old windows XP and drag it into Autocad to do a basic image insertion without browsing the entire network to find the image.
Is there a way to restore this feature? Has you can see on the image, i have an ERROR no fonction definition for IMAGEFILE command
Is it easy to restore?
4 REPLIES 4
pendean
in reply to: Peac3
As a test, if you do use the long method, does it work?
Peac3
in reply to: pendean
yeah if i use the _imageattach command button, i get the popup window and the file browser to get the image i want into the network. But it's too slow and i have to put too much mental effort searching, it's killing me.
To me this is the long method... maybe you think about something else?
DaveFuller
in reply to: Peac3
As I remember, OLE has always been somewhat of a problem. As cumbersome as it can be sometimes, I believe (because I read something here posted by someone who know more than I) the most proper means of inserting an image is to the imageattach. (I think it may have been Dean)
pendean
in reply to: Peac3
”Boost
