I have this situation in 2013, i use to take an image from my left screen file manager in good old windows XP and drag it into Autocad to do a basic image insertion without browsing the entire network to find the image.
Is there a way to restore this feature? Has you can see on the image, i have an ERROR no fonction definition for IMAGEFILE command
Is it easy to restore?
Solved by pendean. Go to Solution.
Solved by DaveFuller. Go to Solution.
yeah if i use the _imageattach command button, i get the popup window and the file browser to get the image i want into the network. But it's too slow and i have to put too much mental effort searching, it's killing me.
To me this is the long method... maybe you think about something else?
