I got a drawing of a house plan with Arabic fonts. In the AutoCAD editor the fonts look normal but when I tried to print the drawing, even to pdf, I got separated letters.
How can I solve that?
Thank you.
Are they actually only separated, or also printed in reverse order?
Every AutoCAD I have seen (at least since 2006, didn't try this on older ones) has printed right-to-left languages left-to-right.
@jz4all wrote:Hi,
separated and in reserve order in the same time.
I've yet to see a working solution for this on AutoCAD. I reported this as a bug, the response was essentially "yes, we know."
- anybody try this on 2015 yet?
We took a brute-force approach and installed Draftsight for those users who need to produce Arabic output.
please see attached solution to PRINT IN ARABIC properly and ENJOY:
Best Regards
Engineer. Ahmad
We don't have that software.
Trying the corresponding trick on DWG to PDF.pc3 or on our Xerox printer didn't work.
