AutoCAD 2013/2014/2015
Distinguished Contributor
6 Kudos
Post 1 of 8
Possible bug with object angle field
293 Views, 7 Replies
07-28-2012 03:43 AM
Draw a 20° sloped line.
Add an object field to the line, the angle shown is 0.3491 and not 20
191 Kudos
Post 2 of 8
Re: Possible bug with object angle field
07-28-2012 06:25 AM in reply to: Exmateria
Not a bug. Angles are stored as Radians.  Use the additional format button and add the factor 180/pi  to convert to degrees.  Hint:  Use the system calculator and copy and paste the actual value into the factor field.
6 Kudos
Post 3 of 8
07-28-2012 08:13 AM in reply to: dbroad
This behavior was not the same in previous releases where angles were displayed in the current units. What happen if I open in AutoCAD 2013 an old drawing created in AutoCAD 2012? Is the angle in radians or converted to the currents units?
191 Kudos
Post 4 of 8
07-28-2012 02:02 PM in reply to: Exmateria
I retract my earlier statement.  It is a change and most certainly a bug.  You should report it via autodesk.com/submitbug
6 Kudos
Post 5 of 8
07-28-2012 02:09 PM in reply to: dbroad
Ok, i will do that.
601 Kudos
Post 6 of 8
07-30-2012 07:42 AM in reply to: Exmateria
Valued Contributor
9 Kudos
Post 7 of 8
07-30-2012 09:04 AM in reply to: Patchy
Thanks, has a patch been posted?
601 Kudos
Post 8 of 8
07-30-2012 09:11 AM in reply to: AUGIfr
