anyone know the command that turns on the window that would display the whole dwg in the upper right portion of the screen.you could pan ,zoom . the field of drawing would change , but the pop window would display the whole dwg and show where u were in respect to your drawing?
its been yrs since ive used autocad and this was before the wheel.
any suggestion would be appreciated
bob
Solved by Patchy. Go to Solution.
Solved by skintsubby. Go to Solution.
I think your talking about the aerial viewer (DSVIEWER) which is no longer part of AutoCAD...
I think (someone will know for definite) it was done away at AutoCAD 2012.
Mark
Who said it's dead?
Type in a period in front of the command and see it for yourself.
i tried it .cool it works, thanks guys greatly appreciated. but when i didi look up acad2012 things removed it did say dsviewer. guess thats why they added the period before it.
thats why i love this forum. always learning things
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
