AutoCAD Forum
Polyline around other polyline objects
6 REPLIES 6
Gelby4
1644 Views, 6 Replies
Is there a qicker way, like an autoLISP or command I'm missing, to create a polyline around other polylines, rather than draw around all of them manually? I want to keep the original polylines, but also to trace essentially a boundary around all of them for plotting purposes.
Tags (1)
6 REPLIES 6
Patchy
in reply to: Gelby4
Get SHRINKWRAP from here:
http://www.jefferypsanders.com/autolisp.html
mattbunner
in reply to: Gelby4
I don't quite understand what you want...If you want to essentially create a copy of the polyline so you have two in the same spot, I would select the polylines, copy with basepoint 0,0, paste with basepoint 0,0. If you want like a border or boundary with the same shape, you could use the offset command.
Gelby4
in reply to: mattbunner
I don't want a copy, though. I only want the new polyline to "copy" (Best adjective, I guess) the exterior of all the other polyline shapes. I don't want the new polyline to have any of the other, interior parts. Just a border.
Gelby4
in reply to: Patchy
What does it do?
Patchy
in reply to: Gelby4
?? It does exactly what you were asking.
It draws a polyline around all your connected polylines.
nestly2
in reply to: Gelby4
If you can enclose the object(s) within another object, you can use the BOUNDARY command.  Your object(s) will be the "island"
Not quite as efficient as ShrinkWrap.lsp, but same result.
”Boost
