Anytime I set up a drawing to print I go to page set up manager, set the plotter or printer, size of paper, etc., anything pertinent to the plot. I have titleblock templates, drawing templates, everything is standard. I recently had to downgrade to AutoCAD 2014 from 2015 due to inner office compatability issues so I'm having to reset everything. Yesterday, I went to plot a drawing I've plotted before but before the change and the plotter was set to none, when I went to select, it said driver has been deleted. I was able to create a PDF then plot but thats not ideal of course. I opened another drawing to plot, it went just fine. I always print 1 first and check before printing the whole set, our plotter is archaic. When I went in to replot on the drawing I just plotted, the plot device was again set to none, and for added fun, every plot device I chose, the driver was missing. I couldn't even convert to PDF. I shut AUtoCAD down, reopened everything was fine. However my object snap then ceased to recognize intersections. Apparent or obvious. Anybody ever had this happen before?
Solved by pendean. Go to Solution.
