AutoCAD 2013/2014/2015
juliewaddell1075
Message 1 of 5 (455 Views)
Accepted Solution
Plot Styles
455 Views, 4 Replies
04-29-2013 10:08 AM
I received a drawing today that doesn't allow me to choose existing ".ctb" files.  Opening the "Plot style table (pen assignments)" from the Page Setup dialogue box.  I can choose "Start from scratch" , use a "CFG" file, or "Use a PCP or PC2" file".  I do not have any CFG files.  I usually use PCP in my "Plot" dialogue box for the plotter pull-down menu.
If you will, please tell me how to use my plot style "BRhalf.ctb" when plotting this drawing.  Also, I'd appreciate a "heads-up" on background information on this drawing's plot style options, vs. the plot style options on many other drawings I have plotted.
Sincerely,
JamJaws
Sincerely,
JamJaws31
If you're used to always having your ctb files available to you in the plot style table and they arent there when you open this drawing, it may be an stb based drawing.  You can switch it to view and use the ctb files, but keep in mind, a plot style other than the one intended to be used when plotting that drawing will not give you the same output as was originially intended by the creator.  So, your individual plot style used to plot this drawing might give you funny lineweights, or at least not print as you would expect from one of your own drawings, if this is not a drawing you created.  The command to make the switch (to see your ctb files) is CONVERTPSTYLES.  Once you've run this you should see the ctb files you're used to as you have told AutoCAD in the past to look somewhere specific for your plot styles.
Hope that helps :smileyhappy:
kpwilson
Message 2 of 5 (441 Views)
Re: Plot Styles
04-29-2013 11:04 AM in reply to: juliewaddell1075
juliewaddell1075
Message 3 of 5 (431 Views)
Re: Plot Styles
04-29-2013 11:44 AM in reply to: kpwilson
This was a very thorough reply and I sure apprecite the answer.  Now I clearly understand when to change someone else's plot style or not.  Thank you!
Sincerely,
JamJaws31
kpwilson
Message 4 of 5 (428 Views)
Re: Plot Styles
04-29-2013 11:52 AM in reply to: juliewaddell1075
Great! Glad I could help :smileyhappy:
New Member
dgadongale
Message 5 of 5 (218 Views)
Re: Plot Styles
01-02-2014 06:58 PM in reply to: kpwilson
I just experienced a very similar situation, your fix got me over the hump. Thanks for sharing.
Post to the Community
New Post
Need installation help?
