AutoCAD 2013/2014/2015
Active Contributor
RFreund
Message 1 of 3 (752 Views)
PDFAttach - Line-weight / Shadding
752 Views, 2 Replies
08-24-2012 03:01 PM
If I attach a pdf or xref a pdf into a drawings is there a way to make the entire pdf a lighter line weight or have it as a 'faded' background?
Thanks in advance!
www.HowToEngineer.com
JasonRuhl
Message 2 of 3 (747 Views)
Re: PDFAttach - Line-weight / Shadding
08-24-2012 08:48 PM in reply to: RFreund
After you XRef in the PDF, select the PDF, then this tab should pop up (Note: I only copied the left side of the tab:smileyhappy:
There should be a fade slider on the tab.
Alternately, a numerical value shows up on the properties tab under the heading "Underlay Adjust"... There's Contrast, (1-100) Fade (1-100), Monochrome (Yes / No) and Adjust Colours for Background (Yes / No), you could enter a value in the Fade field instead of using the slider.
There is no way I know of that you would be able to use to modify the actual lineweights of a PDF. In a vector based PDF with layers included (ie a PDF made using the DWG to PDF converter), you can turn off layers but I have not found a way to actaully modify their properties.
Active Contributor
RFreund
Message 3 of 3 (719 Views)
08-27-2012 06:28 AM in reply to: JasonRuhl
Thanks, It seems fade is what I was looking for. When I fade the PDF it seems to print 'lighter' which is what I wanted. Basically I was drawing over the top of the pdf and wanted the pdf to be a lighter 'shade' as a background.
