for me it's working. So we need more infos.
- alfred -
I'm using AutoCAD 2015. What info do you think might be important?
Thanks In Advance
What means "mapping is incorrect" for you, does that mean:
What driver did you use (and have you migrated that from a previous AutoCAD release)?
Can we have the drawing and the PDF you get as a result plus the info where we have to look fro "mapping is incorrect" ... would be the best one to verify that all.
- alfred -
>> It's when I insert the .pdf as an underlay that the ULAYERS command jumbles them!
I can't reproduce that too, when I attach a PDF the layers can be switched correctly.
As you are using the original DWG to PDF.pc3 (what is correct to preferre that) and Adobe Reader seems also to switch it correct we have now the situation of one PDF you have that does not work correct when attaching into AutoCAD. As long as you can't upload that PDF can you try to reproduce that situation with a new file that does not contain any company data, just dummy polylines so we get a DWG and a PDF that makes it possible for us to reproduce that issue?
- alfred -
Yes, as far as I know it's the 'origional' DWGtoPDF.pc3. It ought to be...
The issue is caused by a certain dynamic, annotative block existing inside another block! Another, but similar, block did not case the issue. They have some different layer names within them.
Another issue I ran across is that the same dynamic, annotative block placed (mistakenly) in PaperSpace then CHSPACE'd will not appear in the PS viewport. ugh!
