Using Acad 2014 I can not for the life of me get reliable results on plot. I have attached 2 jpegs showing what I start with and what the end result is. In some cases lines are added in. Other times lines that I want are removed.
I currently have the 2d viewports setup as hidden wireframe. I have the ISO setup as conceptual with the x-ray effect (note with x-ray off the unwanted lines show up in model and paperspace). I have also tried realistic with the same results.
Any help is appreciated, I am far from an expert and at my wits end.
Solved by nestly2. Go to Solution.
@blk87quest wrote:Using Acad 2014 I can not for the life of me get reliable results on plot. I have attached 2 jpegs showing what I start with and what the end result is. In some cases lines are added in. Other times lines that I want are removed.
You'll most likely need to post your dwg.
Try changing each of the Viewports Shade Plot settings to "As Displayed" via the Properties Palette.
