I just recently started using Autocad 2013 for my PC. When I go to open a file that was saved from a Mac version of Autocad 2013, all of the defined widths of the mtext boxes have shrunk, and sometimes the text styles are overridden. Is there a solution to stop my Autocad from overriding or changing the text styles from the original document? Thanks!
And what font files are being used on the Mac vs the PC? if you want optimum compatability between them, you might be best served only using OOTB SHX fonts.
