AutoCAD 2013/2014/2015
Distinguished Contributor
Karol-Or
Message 1 of 3 (327 Views)
Partial CUI not loaded on startup
327 Views, 2 Replies
01-20-2013 10:28 AM
I made a partial CUI but it isn't loaded when i start Autocad. I have to load it, manually, with the MENULOAD command.
Sometimes, if not always, the LISP programs i entered in the Suitcase of the Load Application command aren't loaded also, and i have to load them, or some of them, manually.
M_Hensley
Message 2 of 3 (311 Views)
Re: Partial CUI not loaded on startup
01-21-2013 03:56 AM in reply to: Karol-Or
After you get your settings like you want them, use WSSAVE command to save your workspace. Later if your settings are not right use WORKSPACE command and set your saved workspace as current.
Valued Mentor
smbrennan85
Message 3 of 3 (293 Views)
01-21-2013 12:38 PM in reply to: Karol-Or
Make sure you get the Service Pack installed if you haven't already. I had some issues with my partial not loading properly from time to time, and ever since I installed the service pack I haven't seen that issue again.
Shawn B.
Follow me on Twitter @That85CADGuy.  ||    Connect with me on Linkedin.
To help improve Autodesk Products, please Click Here to provide feedback.
To help improve the use of these Forums, please  Accept As Solution and  Give Kudos.
