Hello
I have drawn a model that I want to stretch into position. The model works fine if I enter the widths in the properties pallette but I get an error message about overconstraints if I drag the the grips. Any advice on what I am doing wrong please? Am I "over egging" my problem and could I have made the model simpler.
Regards
You have applied FIXED constraint to your model which is creating all the trouble, remove fixed constraint and then apply stretch it works fine. I also suggest you to apply hatch after stratching. I am attching your drawing stretched with no errors using same method as above.
