AutoCAD Forum
Paper space object is under modelspace object
5 REPLIES 5
jorismaes
1979 Views, 5 Replies
I have some building plans in model.
In paper I drew the symbols on it, but I can't bring them in front, they stay underneath modelspace objects.
Is there a way to bring them really to front?
(Modify - bring to front doesn't help)
Thanks in advance!
Joris
5 REPLIES 5
pendean
in reply to: jorismaes
Not a display option, but it can be a plot option.
radar696
Did you try using the DrawOrder command?
I know how it works in model space but have never had reason to try and use it in paper space.
Sure seems like it should do you what you are asking though.
Seems like it should just be a matter of moving those items to the front.
jorismaes
in reply to: pendean
The draworder was correct, but now I (finally) know what the plot option "plot paper space last" is used for.
Thanks for helping! Smiley Happy
Joris
a.p.bik
HELP!
I've got Mtext and dimensions in paper space appearing underneathe everything in the model space. No matter if i set draw order to front or "plot paper space last" it still plots with my text underneathe linework.
Tried draw order of text, draw order of viewport, draw order of linework in modelspace and xrefs. Have tried "texttofront" command to no avail.
Anyone have any ideas?
Im using 2016
Spoiler
Nothing works!
jorismaes
in reply to: a.p.bik
Did you read my post?
In your pagesetup you need to click on: "Plot paper space last".paper.png
Joris
”Boost
