The issue I am having is that the pan/zoom that is usually off to the right of the screen in model and paper space is not longer there. My MBUTTONPAN is set to "1". I would like to know how to turn this feature back on. Can you help?
Cheers.
Solved by sthompson1021. Go to Solution.
Solved by hwalker. Go to Solution.
Welcome to the Forums
NAVBARDISPLAY. Change the value to 1
Howard Walker
NAVBARDISPLAY is the sys var for this but a easy way to control it along with the viewcube and other things is to move your cursor to the top left of the display area. You should have three different choices appear. Click on the - (minus) sign and you can turn it on or off from there.
