Very strange problem here.
I have a number of files that have grown from less than 1MB to 15MB and more.
It's happening when I copy something from one of the large files into a smaller file. The copy or cut process takes about 7 seconds to finally compute, instead of being instantaneous like in a smaller drawing.
It's not a specific object that I'm copying, though. I even tried drawing a new basic line and when I paste it into the smaller file, the file size explodes.
I've audited, purged and -purged numerous times, but nothing works. Even when I delete everything from the file so it's completely empty, it's still some ridiculous size.
Ideas?
Solved by hgasty1001. Go to Solution.
check non-purgable items, look for uStan elements, and if they are there, run DGNPurge to get rid of them,
I think that should be "uStn", aka "MicroStation". There's been a bit of a problem with MicroStation linetypes not purging properly.
