I just moved from 2014 to 2015. Not sure I like it but it might just be a matter af adjusting. One thing I am having a problem with is Osnaps. I turn all but Center off but it still look for all the other points. I know there is a way to stop it but I can't for the life of me recall what it is.
-Dave
Solved by DavidQ. Go to Solution.
I open the Drafting setting dialog box. In the Object snap tab then Clear all. Then I pick the one I want and hit ok.
I had this problem in 2014 but I remeber finding out how to stop it.
I simply typw OS to get the dialog box then choose the one I want. Then I'll do a line comand that I want to start at the center point of the object. It will show ALL the snap points, End, middle, quad. In this case I only want center.
Constraints?
I am going back to r2014 until I can figure this out. I don't have time to waste messing with it right now.
Thanks for trying
I do not know anything about constraints but I do know that if I set my running osanps to only show the center of a circle it should only show the center not the end, mid, quad, ect as well.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
It seems there is something odd going on. I tried the osmode thing. It stays at 4 but still showes all them when trying to snap to the center. I should point out that what I select is not relavent. It does it to any one.
I wonder if I can get my Profile from the 2014 version and put it on the 2015.
I fixed it!!! The Sanp settings drop down box in options -> AM:preferences was set to System settings and the Snap Defaults had the boxes checked. That overrode my running osnaps. Why would they even make it possible to do that? Anyway, I unchecked ALL the boxes in the Power snap configuration dialog box and now all is well ... maybe not all but this problem is gone. 🙂
Thanks for trying to help.
There seems to be two ways to fix the probelm I had.
One was to change the "Snap Settings" (Options / AM:Preferences / Snap Setting change 'system setting' to 'User settings'.
OR
Leave it on System settings and go into the Sanp Default... (button next to the Snap settings) That will open the Power Snap Settings dialog box. To fix my problem I just had to "Clear All' or I could have uncheck all of them one by one and hit apply.
For some reason you can overide the running osnaps with the Power Snap Settings. I do not understand why anyone would want to do that but so be it.
And thats' why none of the rest of us could replicate your issue. Your working with a vertical, niot plain jane vanilla acad. We don't have AM Powersnap, just regular OSnap
