Hey everyone -
I'm working on a basic plumbing layout, I recently moved to my old coworker's computer and every single time I select anything, object grouping turns on and it messes with a lot of things I need to do. Every time I go into option, selection, and uncheck that box, hit apply and ok, and boom, the instant I do anything, everything's grouped again. I've tried shutting AutoCAD down and restarting, tried restarting the entire computer, tried saving under a different file name as well. Nothing worked. I've attached a screenshot or 2 to show you exactly what I mean.
Has anyone else encountered a similar problem or know what may be causing this one?
Sounds like something is changing the system variable PICKSTYLE for you. Maybe a reactor?
See this article for a way to find out what is doing it.
