Hello All,
I have v2015 just installed. I cannot open or find a file through explorer folder view, I only get the command line asking for location. I cannot figure out where the setting is or how it changed. I migrated everything over from v2014.....btw.
This happens on Insert | Attach also (so far as I know)
See attached...
Jeff
Solved by M_Hensley. Go to Solution.
Hello
As you know now : FILEDIA = 1
It's one of the most "populous" System Variable !
and check also : CMDDIA = 1
Because if CMDDIA = 0 you could have some strange side effects ...
Patrice BRAUD
Hint: If you'd like to really impress your instructors, with FILEDIA = 0, you can enter Shift + "~" (the "tilde" character, at the upper-left of the keyboard), followed by <Enter> to force the Select File or Browse to Folder window to appear.
For some reason the popular answer didn't work for me, so thanks for your input on this!
You're very welcome!
And best of luck (and determination) in your studies.
Correct spelling is important.
On the command line, type FILEDIA, hit <Enter>, and then respond by typing 0, followed by <Enter>.
(That is a zero, not the letter O.)
