AutoCAD Forum
open & save command not showing tab in ACAD 2013
2 REPLIES 2
anatho
358 Views, 2 Replies
When I am giving a open command , instead of opening a window, options are appearing on command line.
I can not do 'save as' also.
2 REPLIES 2
kasperwuyts
in reply to: anatho
Check the FILEDIA system variable and make sure it is set to 1.
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
anatho
in reply to: kasperwuyts
Thanks. It worked.
”Boost
