I want to insert a word document with several pages in autocad by the OLE OBJECT function. The problem is the insert only the first page. How to follow the other pages?
The only way I've found to do it is to save the word doc as a PDF and then insert it as a PDF underlay
@patrice.levesque wrote:
Is there a another way to enter text word in autocad and it was linked
If you do not need special Word formatting, you could try using RTEXT.
Save your MSword doc to a .TXT file.
Run the RTEXT command, use the FILE option, pick the TXT file.
If the TXT file changes, a REGEN will update the object in AutoCAD.
Do need to have the doc linked?
I find with excel it is easier to highlight the section needed and then paste into the drawing.
You will still have the option to edit the xls/doc via OLE option from within the drawing.
I have had little success linking docs to drawings.
