AutoCAD Forum
Offsetting Ellipses
9 REPLIES 9
Message 1 of 10
tonypasqualino
3178 Views, 9 Replies
Offsetting Ellipses
When I offset an ellipse Autocad creates a spline.  Is there a way to create an ellipse instead?
Thank you,
Tony
9 REPLIES 9
Message 2 of 10
no, because offseting with a constant distance would not result in an ellipse, mathematical not possible.
Or with other words: to get an ellipse as result object the offset-distance can't be constant, you can try that by creating an ellipse with 100 length/20 height and another one with 140 length and 60 height ... what might be an offset of 20 ... now measure some distances around those tho objects.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
JDMather
in reply to: tonypasqualino
Autodesk Inventor will offset as an equal distance spline or as a true ellipse.
Message 4 of 10
The routine here was made specifically to do just that.  It will do either full Ellipses or partial [elliptical arcs].  It even has the Through option for the offset distance [now, that was really something to figure out how to do!].  The distance between quadrant points will be what's equal [the specified distance if done that way, or in the Through option, the curve will go through the picked point (within a small tolerance) and the distances between quadrant points may be different from that but will be equal to each other], while of course the distance between the original and offset ones will vary elsewhere [which is the reason why AutoCAD's Offset produces a Spline instead, which can be equally (again, within a small tolerance) distant from the original Ellipse all around].
Kent Cooper, AIA
Message 5 of 10
Alfred.NESWADBA
in reply to: JDMather
Hi JDMather,
The result is a true ellipse and the distance at every point between the inner and outer object is a constant?
As I don't have Inventor can you export the above sample please? I can't imagine that the offseted ellipse follows the mathematical rules for an ellipse object and want then to play around with that object and it's curving.
Thx in advance, - alfred -
Alfred NESWADBA
Message 6 of 10
JDMather
in reply to: Alfred.NESWADBA
@Alfred.NESWADBA wrote:
Hi JDMather,
The keyword is OR, not AND.  You can have one OR the other.
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
See Tip #34, pg 14.
Message 7 of 10
JDMather
This is how Autodesk Inventor completes Offset of an ellipse.
Notice in the first offset that a temporary vertical axis appears - this is indication that a true ellipse will be created.
In the second offset I picked further away from the vertical axis and Inventor returns a equal distance spline offset.
Message 8 of 10
Alfred.NESWADBA
Thank you and please appologize about my minimalistic English and that I didn't see that difference clear enough.
- alfred -
Alfred NESWADBA
Message 9 of 10
JDMather
I was impressed that you realized that there is a difference.
Most who offset an ellipse do not realize what they are really doing.
Message 10 of 10
       If a spline is not acceptable; draw another ellipse.
”Boost
