Has anyone ever seen an issue as shown in the attached file? The fonts should all be simplex but it's comming up with a mix of arial and simplex. One of our users is having this odd issue and he then goes into fix it saves his drawings but when he goes back to that file it returns. This is happening in almost every drawing of a 300 drawing design package.
I've looked at the styles and our custom routines but don't see any issues anywhere.
Any help would be appreciated.
Dylan
you'll need to post a dwg that exhibits the issue. Try wblocking out a block of text, open to make sure it's funky, and then post that
picture really doesn't give me any clues
Here is a copy of the actual cad file. I stripped out everything but the issue text.
Dylan
Ok, there are a lot of overrides in that chunk of text. Google for StripMText.lsp and run that to clear out the font swapping out.
you've also got a number of text objects that consist of a single space..... If you set QTEXT to "ON", and regen, you can select and erase them
then set QTEXT back to off...
I'm getting this too. I think it's a problem with the font definition itself, 'cos if I change the textstyle to another font style, it's all peachy again.
In my case it's the 'Simplex.shx' font - I think it might be corrupted. Try downloading a 'fresh' one..
