AutoCAD Forum
obscure lines is very slow
7 REPLIES 7
Message 1 of 8
stefan.hofer
566 Views, 7 Replies
Since Autocad 2015 SP2 it takes forever! to print PDF's
obscure lines while printing take 10-20min instead 10sec in SP1, especially in Perspectives.
also with very simple drawings.
Someone know a solution for this problem?
7 REPLIES 7
Message 2 of 8
braudpat
in reply to: stefan.hofer
Hello
Unfortunately the SP 2 is sometimes "erratic", so please Un-Install and come back to 2014 + SP 1 !
But before, have you some text styles with the "Big Font" option enabled ?
Because there is a specific "Big Font" Patch Post-SP 2 :
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autoca...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 8
pendean
in reply to: braudpat
In addition to other tips (and yes, remove SP2 first), see if this is a fix if you use HP printers/plotters http://latitude-it.net/hp-designjet-plotter-drivers-and-windows-8/
Message 4 of 8
stefan.hofer
I don't use "Big Fonts" and there is no HP printer connected.
I've tried the BigFont Hotfix, but still the same problem.
i deinstalled SP now. and it works perfect again (with SP1). thank you.
but i miss the ctrl-drag copy-layout feature -.-
Message 5 of 8
Hi s.hofer,
we would need to investigate the described further and take it off-line.
In advance, thank you for your cooperation to this.
Cheers,
Martin Langolf
Martin Langolf
Message 6 of 8
braudpat
in reply to: Martin_Langolf
Hello Martin
I will appreciate to know asap if the problem is linked to the SP 2 for 2015 ?
or if it is a "more general" 2015 problem ?
Thks in advance, Patrice
Patrice BRAUD
Message 7 of 8
stefan.hofer
I'ts only a SP2 problem.
It works good/fast with SP1
Message 8 of 8
Hi s.hofer/braudpat,
Thank you for your updates to this.
I have tested this on my end, using linetypes that ship with AutoCAD and all appears OK. - A PDF file is generated in a few seconds.
Settings used:
  1. OBSCUREDLTYPE = 7
  2. VSOBSCUREDLTYPE = 7
I hoped we can investigate this offline - to keep the forum tread short.
However, please provide a sample file for testing.
Once received, I will be able to proceed further.
BTW: Using the CTRL+drag and drop to the left hand side, seems also to work just fine here on my end. - SP2 is installed.
Cheers,
Martin Langolf
Martin Langolf
”Boost
