Since Autocad 2015 SP2 it takes forever! to print PDF's
obscure lines while printing take 10-20min instead 10sec in SP1, especially in Perspectives.
also with very simple drawings.
Someone know a solution for this problem?
Hello
Unfortunately the SP 2 is sometimes "erratic", so please Un-Install and come back to 2014 + SP 1 !
But before, have you some text styles with the "Big Font" option enabled ?
Because there is a specific "Big Font" Patch Post-SP 2 :
Patrice BRAUD
I don't use "Big Fonts" and there is no HP printer connected.
I've tried the BigFont Hotfix, but still the same problem.
i deinstalled SP now. and it works perfect again (with SP1). thank you.
but i miss the ctrl-drag copy-layout feature -.-
Hello Martin
I will appreciate to know asap if the problem is linked to the SP 2 for 2015 ?
or if it is a "more general" 2015 problem ?
Thks in advance, Patrice
Patrice BRAUD
Hi s.hofer/braudpat,
Thank you for your updates to this.
I have tested this on my end, using linetypes that ship with AutoCAD and all appears OK. - A PDF file is generated in a few seconds.
Settings used:
I hoped we can investigate this offline - to keep the forum tread short.
However, please provide a sample file for testing.
Once received, I will be able to proceed further.
In advance, thank you for your cooperation to this.
BTW: Using the CTRL+drag and drop to the left hand side, seems also to work just fine here on my end. - SP2 is installed.
Cheers,
Martin Langolf
