ObjectARX
ObjectARX Wizards for Visual studio 2012
18 REPLIES 18
Message 1 of 19
5467 Views, 18 Replies
is there a ObjectARX Wizards for C++2012/visual studio 2012?
18 REPLIES 18
Message 2 of 19
diegoal
Did you get ObjectARX or DotNET Wizards for Visual studio 2012?
I'm having problems here too...
Diego Álvares
Civil Engineer @ Trento Engenharia Ltda.
www.trentoengenharia.com.br
Autocad Civil 3D 2010 to 2017 - Infrastructure Design Suite
Windows 7 64 i7 4770 @3.40GHz 8GB Ram GeForce GTX 760
Please use the Accept as Solution or Kudo buttons when appropriate
Message 3 of 19
pendean
Message 4 of 19
in reply to: pendean
Dear friend,
I have been installed the ObjectARX Wizards for Visual sutdio 2010, but I can not find the toolbar in the visual studio 2012 and there is no addin item could add when right click the mouse on the visual studio tool bar.
Hope you could give some clue, with great appreciate!
Message 5 of 19
diegoal
When you run ObjectARX 2017 under Visual Studio the ribbon tool disappears if you are trying edit & continue. This is a known issue.
Diego Álvares
Message 6 of 19
ObjectARX2016 the additional toolbar is also cannot find.
Message 7 of 19
Alexander.Rivilis
There isn't any ObjectARX toolbar since ObjectARX Wizard 2013.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 8 of 19
in reply to: Alexander.Rivilis
But how can I use the wizard to build the objectarx class ?
Message 9 of 19
Alexander.Rivilis
What do you mean about "to build the objectarx class"? Menu Project->Add Class...->ObjectARX:
Expert Elite Member
Message 10 of 19
Great thanks! But how can I add the command use wizard, dear friend!
Message 11 of 19
Alexander.Rivilis
It can be done with help of ACED_ARXCOMMAND_ENTRY_AUTO macro. You can create new project (with help of ObjectARX Wizard) and read comments in acrxEntryPoint.cpp file about using ACED_ARXCOMMAND_ENTRY_AUTO macro.
Expert Elite Member
Message 12 of 19
Yes I konw that, but I think it just a little uncustomed, Great thanks for your reply! my friend.
Message 13 of 19
Dear Friends,
One more question hope you could give some clue.
I have been creat a customer object for an reactor but the file cannot save and waring one or more object cannot save into the specify format, the process have not complete, so cannot creat any file.
this is a common question for the customer object and confused me long time.
Message 14 of 19
Alexander.Rivilis
Please create new topic with your's question and provide code.
Expert Elite Member
Message 15 of 19
Great thanks
Message 16 of 19
Great thanks, link as below:
Message 17 of 19
Message 18 of 19
tbrammer
You can't. There is no "Add command" anymore. Just add commands manually.
See also here.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 19 of 19
tbrammer
in reply to: tbrammer
Oops. Just ignore my postings in this thread. I didn't see the posts after 15-07-2016 05:52 PM
”Boost
