is there a ObjectARX Wizards for C++2012/visual studio 2012?
Did you get ObjectARX or DotNET Wizards for Visual studio 2012?
I'm having problems here too...
Dear friend,
I have been installed the ObjectARX Wizards for Visual sutdio 2010, but I can not find the toolbar in the visual studio 2012 and there is no addin item could add when right click the mouse on the visual studio tool bar.
Hope you could give some clue, with great appreciate!
When you run ObjectARX 2017 under Visual Studio the ribbon tool disappears if you are trying edit & continue. This is a known issue.
Facebook | Twitter | LinkedIn
@Anonymous wrote:
But how can I use the wizard to build the objectarx class ?
What do you mean about "to build the objectarx class"? Menu Project->Add Class...->ObjectARX:
@Anonymous wrote:
Great thanks! But how can I add the command use wizard, dear friend!
It can be done with help of ACED_ARXCOMMAND_ENTRY_AUTO macro. You can create new project (with help of ObjectARX Wizard) and read comments in acrxEntryPoint.cpp file about using ACED_ARXCOMMAND_ENTRY_AUTO macro.
Please create new topic with your's question and provide code.
