AutoCAD Forum
object selection
3 REPLIES 3
mikec
468 Views, 3 Replies
object selection
Hello, I noticed I cannot select more than one object at a time by clicking individual lines. What Do I need to change? Anybody?
Thank you,
Mike.
3 REPLIES 3
hwalker
in reply to: mikec
Welcome to the Forums
PICKADD variable. Change it to 1 or 2. 2 is the better option
Howard Walker
Left Handed and Proud
steve216586
in reply to: mikec
PICKADD = 0 ; Hold Shift and Left Click to select or deselect other entities.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
dslocum
in reply to: hwalker
Hello, I am also experiencing this problem but only with C3D entities. My PICKADD variable is set to 2. When selecting normal cad linework and text it works as it should. However, when selecting C3D labels I can only select one object, then my cursor changes from a crosshair to a "select" (arrow) cursor and I have to left click in a blank space to get the crosshair back so I can select a second object. Is there another variable that only affects C3D object selection? Appearently something isn't set correctly.
”Boost
