AutoCAD Forum
Object Isolate question
2 REPLIES 2
octavio2
222 Views, 2 Replies
When I isolate in AutoCAD 2015 I still see the unisolated elements faded on the background,  and I consider that to be a distraction, so I want to see only the isolated elements like in the old versions of AutoCAD.
Where I control this so only the isolated elements are seen?
Thanks in advance.
2 REPLIES 2
Alfred.NESWADBA
in reply to: octavio2
do you mean command _LAYISO or command _ISOLATEOBJECTS?
For command _LAYISO you can use the option "SETTINGS" during the command is active to make "Layer Off" or "Lock and Fade" the option you like (this can also be set within the layermanager ==> Settings).
For the command _ISOLATEOBJECTS I would not know that there is a possibility for fading the objects at all.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
octavio2
in reply to: Alfred.NESWADBA
Thanks, Alfred.
”Boost
