When I isolate in AutoCAD 2015 I still see the unisolated elements faded on the background, and I consider that to be a distraction, so I want to see only the isolated elements like in the old versions of AutoCAD.
Where I control this so only the isolated elements are seen?
Thanks in advance.
Solved by Alfred.NESWADBA. Go to Solution.
do you mean command _LAYISO or command _ISOLATEOBJECTS?
For command _LAYISO you can use the option "SETTINGS" during the command is active to make "Layer Off" or "Lock and Fade" the option you like (this can also be set within the layermanager ==> Settings).
For the command _ISOLATEOBJECTS I would not know that there is a possibility for fading the objects at all.
- alfred -
