AutoCAD Forum
Numbering in a table?
3 REPLIES 3
cadpro78
3564 Views, 3 Replies
This may have been covered in a previous posts so please forgive me.  I would like to know if AutoCAD can list in a table form a set of numbers (001, 002, 003, 004, 005, etc.).  When I put in the number in table, it just comes up with (1, 2, 3, 4, 5, etc.)  Basically, is there a way to trick AutoCAD into placing the '00' in front of the number?
Thanks in advance.
3 REPLIES 3
nrz13
in reply to: cadpro78
Select your column of cells (shift+select) → Right-click on one of the cells → Select Data Format... → Change to "Text".  This will allow you to put in whatever you want.  There is also an option to add a prefix under "Whole Number", but I think you'd have to change that manually once you got to 10.  Not sure, though, because we only ever use text so we can put in whatever we want.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
sthompson1021
Hi, the only way I have found to do it is change the data format of the cells to text.
cadpro78
Worked great.  The other way with the "whole number" didn't end up with the result I wanted.
”Boost
