This may have been covered in a previous posts so please forgive me. I would like to know if AutoCAD can list in a table form a set of numbers (001, 002, 003, 004, 005, etc.). When I put in the number in table, it just comes up with (1, 2, 3, 4, 5, etc.) Basically, is there a way to trick AutoCAD into placing the '00' in front of the number?
Thanks in advance.
Solved by nrz13. Go to Solution.
Select your column of cells (shift+select) → Right-click on one of the cells → Select Data Format... → Change to "Text". This will allow you to put in whatever you want. There is also an option to add a prefix under "Whole Number", but I think you'd have to change that manually once you got to 10. Not sure, though, because we only ever use text so we can put in whatever we want.
Hi, the only way I have found to do it is change the data format of the cells to text.
