Ok, my problem is I select the layouts to publish. I right click to "publish selected layouts", it does it's thing. When the publish window comes up there is only 1 layout listed and not the layouts that were once highlighted to publish are no longer highlighted. Anyone else having this issue? Thank you in advance for any help.
Tony
Solved by pendean. Go to Solution.
Create a new file, with new layouts, and test. Still a problem?
Attached is a test file I created for you, can you do the same here too?
