First... I'm "very new" in this topic, so excuse me if I ask "wrong questions".
I have a design with more 3d objects (sub-parts) and I would like to identify where (if there are any) the solids are intersecting each other.
Something like here:
Of course that I could make an intersection and I would get the result, but there are a lot of objects (for me) and I would need to make a copy, and to see if I have results ... and is not so straightforward.
the question is: Is there any option to identify this situations?
Thank you,
BR,
Adrian
Solved by nestly2. Go to Solution.
I use AutoCad 2014 and when I want to check for interferance, I go to Modify, Solids Editing, and use the intersect tool.
hope this works for you, Larry
INTERFERE command. The default behavior is just to display where the interferences occur, but by unchecking the box that says "Delete interference objects on close, a new solid will be created much like happens when using INTERSECT.
