AutoCAD Forum
[.NET] acdbHandEnt in autocad 2015
3 REPLIES 3
fsztuczny
517 Views, 3 Replies
In autocad 2013 and 2014 work the following code:
    [DllImport("acdb19.dll",
      CharSet = CharSet.Unicode,
      CallingConvention = CallingConvention.Cdecl,
      EntryPoint = "acdbHandEnt")]
but in 2015 was not. Does anyone have an idea how to fix this? If someone finds a solution, then how to perform a in one code selector designed for three versions of autocad?
3 REPLIES 3
artc2
in reply to: fsztuczny
In 2015 the dll is acdb20.dll
fsztuczny
in reply to: artc2
Thank you very much. Is it possible to conditional load the correct file depending on the version of AutoCAD running (in the same code - dll assembly), or must I separately compile for versions 2014 and 2015?
Dale.Bartlett
I have struggled to find documentation regarding the acdb??.dll versions. Can anyone provide a link(s), and secondly, can this be conditionally compiled? Many thanks, Dale.
______________
Yes, I'm Satoshi.
”Boost
