In autocad 2013 and 2014 work the following code:
[DllImport("acdb19.dll",
CharSet = CharSet.Unicode,
CallingConvention = CallingConvention.Cdecl,
EntryPoint = "acdbHandEnt")]
but in 2015 was not. Does anyone have an idea how to fix this? If someone finds a solution, then how to perform a in one code selector designed for three versions of autocad?
Solved by artc2. Go to Solution.
Thank you very much. Is it possible to conditional load the correct file depending on the version of AutoCAD running (in the same code - dll assembly), or must I separately compile for versions 2014 and 2015?
I have struggled to find documentation regarding the acdb??.dll versions. Can anyone provide a link(s), and secondly, can this be conditionally compiled? Many thanks, Dale.
