Hello Everyone
So I am currently having an issue in autocad where we have a drawing set of approx 50 dwgs that are all being pdf'd at A0 size, and then printed at 11x17 or A0 depending on the function of that set. They are adamant that this is the method desired to do this. And it works quite alright usually, the drawings are all legible at 11x17 and at the A0 scale, except for three drawings. These are the only three drawings in the set which are actually filled with 9 small pdfs viewported in from model space instead of an archtiectural drawing from model space. But when I print these sheets scaled down from the A0 the title block comes out so light grey its barely readable. I feel like it has something to do with the lineweight issue in the drawing, maybe a scaling thing but I cant for the life of my make the drawing print as consistently as the others in the set.
Any help you could give me would be truly apprectaited.
Solved by kristian.pal86. Go to Solution.
Anyone else have any ideas as to what the issue is here?
I feel like the "scale lineweights" checkbox might be a part of the problem when I am making the pdfs
Thanks in advance
Hello to eveyrone who helped out or gave suggestions for this issue
I discovered what the issue was in the end. It turned out that the images placed into our sheets were originally jpegs..
I did not realise this but because we had scale lineweights checked in our plot style I believe it was incorporating each jpeg as a single, darker lineweight into the calculations of scaling down all the lineweights in the plot. This was making our overall plots much too light. I resolved this by using pdfs in the sheet instead of jpegs and I have found that there is a much more logical and proper darkness to the lines after the scaling down of the pdf lineweights over the jpegs lineweights, and it also has a better range depending on the size of our plots. Thanks again to everyone who gave ideas!
