"Hi, i am using autocad 2013, and
My properties dialog is blank. Pick-first is set to 1
I have completely repair, registry cleaned, but now this problem is continues. can you help any one ?"
I know you said you ran a repair, but some programs (Norton) continually mess up the registry settings needed by the Properties palette. http://usa.autodesk.com/getdoc/id=TS1052681
@Anonymous wrote:
I had cleard window registry with Ccleaner, but same problem continue.
AFTER you run a registry cleaner, THEN you have to run a REPAIR on the install.
Before you do the Reinstall, uninstalll your registry cleaner, and throw away the disks/delete the download, and never run one again.
