AutoCAD Forum
My new line type won't display correctly?
6 REPLIES 6
mgalicki
1229 Views, 6 Replies
I edited the linetype file (acad.lin) to create a "sewage line" ----SS----SS----SS----
I copied the "fence line"
*FENCEMG,----X----X----X----X----X----
A,.5,-.1,["X",STANDARD,S=.1,U=0.0,X=0.0,Y=-.05],-.3
and edited it to
*SEWAGE_LINE,sewage line ----SS----SS----SS----SS----SS----
A,.5,-.2,["SS",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.2
But instead of getting the 2 SS' in the line, I'm getting the X
Any help would be greatly appreciated.
Mark
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
6 REPLIES 6
doni49
in reply to: mgalicki
I see two possibiltiies.
  1. The lines in your dwg file are actually using the fence linetype.
  2. After copying the fence linetype (in the lin file) and renaming the copy, you saved it before changing the X to SS.  After confirming the lin file DOES have the SS in the definition, reload it into your dwg file.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
mgalicki
in reply to: doni49
Thanks for the reply Doni,
I did resave the file. take a look at the screen shot I've attached.
The linetype managere dialog box shows, description ___SS____SS___SS
but, the Appearance shows the ___x___x___x
Pretty freaky, It's got me puzzled.
Thanks for your time.
Mark
Autodesk MEP 2019
doni49
After seeing your screenshot, I really think it's #2.
Open a new dwg file, add your SS linetype to it.  Does it work there?
If yes, the lin file is ok.  So now go back to your dwg file and reload the linetype (pretend the linetype isn't already defined in the file and then when acad asks if you want to redefine the existing linetype, answer YES.
Don Ireland
mgalicki
in reply to: doni49
That did it! Thanks Doni.
Autodesk MEP 2019
doni49
I'm pleased to hear that you got it resolved. Thanks for letting us know. Have a great day!
Don Ireland
mgalicki
in reply to: doni49
Hey Don,
Got another one you may be able to give somw assistance to?
I wanna make a line type with diamonds in it instead of the ss or x.
I found this line def but I need to set it's parameters to rotate it 45 degrees:
Not sure how to do this?
*DIAMOND_LINE,diamond line ---<>---<>---<>---<>---<>---<>---<>---
A,.001,-.2,["><",STANDARD,S=.105,R=0.0,X=-0.11,Y=-.0457],-.00001
Autodesk MEP 2019
”Boost
